PDA
View Full Version : OD housings 47re to 47rh????
1-5-3-6-2-4
12-01-2008, 01:26 AM
are RH and RE od housings interchangable? I need to convert my 47rh 4wd to 2wd and I just need a OD housing case shaft and yolk. can I rob a 47RE for its OD housing? it will give alot more options at the wrecker
dozer12216
12-01-2008, 04:11 AM
Not so lucky. RH has a governor on output shaft, RE doesn't. Housings must be different also. JMHO
