O F V part no. id question ?
hi
got a new ofv off e bay and it has a diff part no than the old one ???
also lookes diff , no bolt/cap to remove to be able to get at the spring to strech it if you had a mind to ???
end that should have a cap lookes to have a ball presed into it ??
old bosch pn 24174-13101
new bosch 14174-13047 ?????? is it correct part ????
thank you !
thank you !
hi
yep seller said can use eather but one like my old one is $65.00
i will prob open my old one just to see if the spring is shorter than it is supposed to be ?
guess i will keep the old one in the glove box as there is no fixin the new one ?
did you check your old one for psi or spring length ?
1 Post
I kept the old one as a spare as well, But did not check fuel pressure before or after I figured with just about a 100,000 miles on the truck to just change it. I also read on another site that they are the same and will function just fine.plus for $25 and 5 minutes time could really go wrong.
NoSparkplugs
06-24-2009 07:08 PM
77machomopar
01-24-2008 05:30 AM
SmokinFive9 4x4
03-07-2005 06:55 PM
12PACK
01-02-2005 06:48 PM
