Nv5600 - Lost 4th Gear
Old 01-13-2004, 09:07 PM
mysterync's Avatar
5Speed, Typo fixed
I just lost 4th gear, (well its grinding when going to shift) , im getting some bearing noise only in 4th and 5th , mostly when letting off the throtle. How hard is this to fix? Any thoughts or anything i should know ? Would i be better off getting it fixed or doing it myself?
Old 01-15-2004, 03:13 PM
DeereDiesel's Avatar
Probably countershaft problems. Just did a 5spd countershaft after our last pull. New one is about 150+-. Missing teeth on the constant mesh is common.
carty
Old 01-15-2004, 08:16 PM
frostie's Avatar
I would not advise you attemting to repair the 6 speed, It is one crazy transmission, It has 6 shift shafts and is a puzzle just to get it apart. My friend and I disassembled one and decided to get a reman. It was all we could do just to get the core reassembled. If you attempt it then I hope you have lots of time and patience good luck
McGillacutty09
02-08-2010 07:48 AM
6speedcowboy
13
09-13-2007 10:49 PM
MunK
08-12-2007 10:10 AM
243
05-02-2005 07:57 AM
1st gen Hobie
10-08-2004 12:20 PM
Quick Reply: Nv5600 - Lost 4th Gear
