NV5600 inplace of 4500
Old 04-30-2007, 01:00 PM
Sootin's Avatar
Has anyone done this to their '94-'98 12V? is it possible?
Old 04-30-2007, 01:22 PM
PourinDiesel's Avatar
Yeah its possible. SmokinDodge12V did it to his old 12v.
Old 04-30-2007, 01:39 PM
gunracer1's Avatar
not that hard a swap as long as you get the doner pieces.
Old 04-30-2007, 06:39 PM
tony597fitter's Avatar
I was thinking of doing this conversion also, until I heard and seen how much a nv5600 is and how slow it shifts.
Old 04-30-2007, 08:04 PM
Captain's Avatar
i have a 5600 and the the full conversion kit for 2nd gens. All you would need is the crossmember if you dont have a 98 or (I think someone said this once) turn your stock one around or smoething? Its all for sale and the 5600 is will be comming back from bluemanthauls. If you get me befor it comes back it might be able to get shipped right to you free if you get it shiped to a buisness with a dock or pick it up at the terminal
Old 04-30-2007, 08:54 PM
Valv's Avatar
What ? I have both NV4500 and NV5600 and the 6 speed is sweet. That's the PERFECT transmission if you want to tow, spaced perfect for the Cummins.
Speed of shifting is same if not better than 4500
Old 05-01-2007, 04:04 PM
1320's Avatar
I did it. I used my oem crossmember but its a 98. I also used my bd short shifter from the 4500. They said no, but it was easy. Shifts great. I run amsoil, with two coolers, (I think I got them from Genos).
The whole swap was right at 3000 with driveshaft s etc. I sent my disc back to petter @ SB to change the hub. The OD is a tiny bit more also, so the top end is fun empty. I drive most guys right into the limiters.
LAWN GUY
13
06-29-2007 01:28 PM
np205
02-07-2007 07:30 PM
v8440
04-10-2006 04:05 PM
RamThatStroker
05-29-2003 07:38 PM
Superduty12v
22
10-11-2002 07:42 PM
Quick Reply: NV5600 inplace of 4500
