nv4500max H.P
Old 01-14-2008, 09:32 PM
dieselboy59's Avatar
nv4500max H.P
How much H.P will a nv4500 hold.And can you run in 5 when towing .any input would be great.
Old 01-14-2008, 09:39 PM
displacedtexan's Avatar
A lot. People are running over 600 through them.
I run in 5th towing all the time.
Old 01-14-2008, 09:56 PM
how much H.P are you running
Old 01-14-2008, 10:05 PM
Not much
I haven't dynoed. I have a 215 pump, with a 100 plate, 3k GSK, 16.5* timing.
Old 01-14-2008, 11:00 PM
Big Blue24's Avatar
I tow in fifth and as long as you got a stock turbo, there ain't no way you are putting any more torque through it than the next guy. As long as you have the fifth gear nut upgrade, you should be able to tow in fifth with all the HP in the world. As long as you keep the R's above 1600 or so. Otherwise, you can starve it for lube.
Old 01-15-2008, 08:06 AM
J Lent's Avatar
I tow in 5th all of the time. When my synchros went out at 140k, 3rd gear had the most wear out of all the gears.
Old 01-15-2008, 09:05 AM
JDGPULLER's Avatar
do any of you 4500 guys have any trouble keeping oil in the thing?
I have one with the big input shaft and a dual disk It seems to leak oil into the bell housing if you try to run extra oil in it, and no the vent is not plugged.
I never had a drop till I went to the big shaft, is the seal for the big shaft the same as a 5600 seal?
Old 01-15-2008, 09:26 AM
J Lent's Avatar
Are you sure it is the tranny leaking? I thought my tranny or rear main was leaking & turned out to be the valve cover gasket running down the back of the engine.
Old 01-15-2008, 10:07 AM
TxDiesel007's Avatar
towed over 20K more than a few times..
tow in fifth when im on flat land all the time. just not with that much weight. I do tow a two horse or a sixteen foot tag or gooseneck (stock) in fifth and have even gone as far as a 24 foot empty single axle gooseneck on flat land...
Im at about 500 rwhp per say so they do hold... I just snapped mine tho not to long ago will start a thread soon, but it was after 200Kmiles of towing so they do reach a breaking pt eventually... im runnin a rebuilt from standard transmission as we speak...
Rick
Old 01-15-2008, 12:37 PM
Djasik's Avatar
Why is 3rd like that? It seems weither its a little truck or a one ton dodge, 3rd always fails first, just wondering.
Old 01-15-2008, 12:46 PM
haloman's Avatar
Don't lug it and throw the power at. You'll overtax the cooling system before the tranny IMHO.
Old 01-15-2008, 12:48 PM
haloman's Avatar
Most used gear I bet. You don't always downshift to 2nd when doing a rolling stop. I think 3rd gear gets lugged alot in our trucks.
Old 01-15-2008, 05:10 PM
Tate's Avatar
Count how many times you shift into that gear, especially in city driving. Speed up, shift to third, then to fourth, then back to third, then second at a light, back to third, up to fourth, back to third . . .
Old 01-15-2008, 10:02 PM
Ocmechanx's Avatar
I don't know bout the coolin sys but I know that luggin it and throwin the juice to it is heck on input shafts.
I stripped both countershaft and mainshaft 5th gears clean of teeth, gutted the inerds of the 5th shift collar, blew third gear off the countershaft once, input shaft grenaded once, and never hooked it to a sled.
Sad thing about it was I didn't drive like an idiot all the time, really erked me that all the kids round here were runnin around grabbin and crammin gears and they had no prob at all outta theirs.
Old 01-16-2008, 12:53 PM
MikeR's Avatar
Your EGT's will be dangerous before the 5spd even cares about it.
