NV4500 knock
Old 09-01-2008, 08:43 AM
Scrambler250's Avatar
NV4500 knock
I was towing a camper this weekend, and on my way, I got off the interstate on an exit ramp. As I was decelerating down the ramp, 5th gear, I started hearing a slow knock coming from the transmission. The knock was steady, but at a completely different RPM than everything else. It almost sounded like something was around the driveshaft, hitting the body, but it was slower than the driveshaft would have been turning. The noise only came when decelerating, and in all gears except 4th. After 10 miles or so, it started making the same noise on acceleration too, but still not in 4th. The noise also seemed to get louder the further I went. I get no noise when in neutral, or when the clutch is in. The noise does seem to speed up with higher RPM's. Any idea what this could be, and why it's not happening in 4th?
Old 09-01-2008, 10:13 AM
Number47's Avatar
4th is direct drive but i dont have anything else for ya without hearing the knock
Old 09-02-2008, 08:19 AM
johnyb59's Avatar
I could possibly be a broken gear tooth
Old 09-02-2008, 09:33 PM
dozer12216's Avatar
Nut on fifth gear has worked loose. There is a upgrade kit with locking device to hold better. you should replace fifth gear as it moves on splines. New will be tighter(trust me), along with jamb kit. It can be repaired without pulling tranny, by a knowledgable person. A FSM helps a bunch. Do not run in OD below 57.8 MPH in future. You are lugging engine / tranny.
Old 09-20-2008, 08:43 PM
Broken gear tooth was correct. Input gear had a broken tooth, reverse idler had some broken teeth, and forward most countershaft gear had a bunch of broken teeth. Fifth gear looked fine/tight. I'm now weighing the cost of the gears, and tools to rebuild it, vs. buying a reman. Any suggestions?
Old 09-21-2008, 07:29 PM
towpather's Avatar
I went the rebuild route with a new input shaft,mainshaft,syncros,bearings. Nothing on the countershaft. If i had to do it again i think i would swap it with a reman.
Old 09-21-2008, 08:16 PM
RickCJ's Avatar
Blumenthals rebuild for $1600
Old 09-29-2008, 12:34 AM
MikeR's Avatar
With that much screwed up, I'd go the reman route.
Zee
03-23-2010 09:54 PM
HappyGA
15
10-16-2006 08:21 AM
Hoss
30
10-03-2006 02:57 PM
sinwagon2500
16
01-10-2004 01:34 PM
Quick Reply: NV4500 knock
