nv4500: '97 2wd vs. '02 4wd
Old 09-25-2008, 09:54 AM
Scrambler250's Avatar
Will a '97 2wd nv4500 be used to replace a 4wd nv4500hd? I know the tailshaft housings are different, but would it be as easy as swapping my 4wd housing onto the 2wd case? My biggest concern is that I've seen some specs indicating the '97 used something like a 30 spline output shaft, and the '02 was a 31 spline. I'm guessing that means my transfer case won't fit on the '97?
Old 09-29-2008, 12:20 AM
MikeR's Avatar
The difference is:
the mainshaft on the 2wd is almost twice as long as the 4wd mainshaft.
That's why that tailshaft housing is longer on the 2wd.
You can use the tranny, only if you're gonna install a new fully splined mainshaft to fix the 5th gear issue.
Old 09-29-2008, 09:52 AM
rob24vctd's Avatar
Here are good heavy duty mainshafts, I ahvent had a problem yet.
http://www.torqueking.com/torque%20king%20nv4500.htm
Kody
05-27-2010 06:25 AM
93Fury
03-31-2010 01:33 PM
Jordan5687
02-18-2009 02:48 PM
v8440
10-25-2006 11:59 AM
1320
05-06-2003 06:30 PM
Quick Reply: nv4500: '97 2wd vs. '02 4wd
