nut size??????
1 Post
nut size??????
what size is the nut on the pitman arm on an 02 ??? About to install a DSS I hve the 1 1/4 deep but I need a socket for the factory nut maybe 32,33 mm?????
I believe it was 32mm. At any rate I had to buy a set from harbor freight to get one and if I remember right the 32 fit a little loose so maybe it is actually a 31mm. I didn't have any problems using a 32mm tho. Build on union bro!
1 Post
Thanks J , couldn't find a 32 mm so I gave it a try with a big cresent wrench, came loose way to easy, definitly not 185 ft/lbs like your told to put on the new nut/shaft
Clane
06-02-2012 03:31 PM
