np 205 gears grinding
Old 07-01-2007, 07:09 PM
mullishacrew's Avatar
howdy, on my 93 250 with the np 205 transfercase, i am having troubles with the transfercase it wont go into 2 wheel inless you ram it really quick, or if move the shifter slowly it wont go in 2 wheel at all and just grinds, my uncle put new hubs into it before i got it, would there be a problem like that if he never installed them correctly? and apparently he said it wont go into 4 hi? is there something i can do to get this to work? thanks Gregg
Old 07-01-2007, 08:41 PM
OX1
OX1's Avatar
On automatics, it's sometimes almost impossible to get them not to grind going from nuetral to 2WD. I assume you have taken it out of gear, in gear it will grind no matter what you do. 2WD to 4WD should slip right in unless the front hubs are unlocked and you are moving at speed. The good news is I have been grinding those 205's at will for 20 years and it never hurt one of them.
Old 07-01-2007, 08:44 PM
simplysmn's Avatar
correct me if I am wrong but to change transfercase dont you put transmission into netural first mine changes easy that way .
Old 07-01-2007, 09:00 PM
yeah i pout it in neutral all the time just a real pain to get popped into gear
Old 07-01-2007, 10:16 PM
simplysmn's Avatar
what gear oil you running ? mine I believe is 80/90 wt
Val
Old 07-01-2007, 10:30 PM
im not to sure what is in there at the moment becasue i got the truck from my uncle, bu ti will be driaining it out and putting the weight you say in, im all the way up in kitimat b.c like 6 hours from alaska
Old 07-01-2007, 10:40 PM
simplysmn's Avatar
It also may be the cold weather up yer way ?
Val
Old 07-02-2007, 04:52 PM
Guys, please keep all discussion of buying and selling parts off the forum. Use the PM system or the classifieds.
dieselguy1974
02-26-2012 02:43 PM
thedieselboy
12-31-2007 09:23 AM
93beater
02-28-2007 09:28 AM
grizzlydiesel
03-16-2005 05:21 PM
cLAYH
02-06-2004 10:59 AM
Quick Reply: np 205 gears grinding
