How not to fix your steering coupler
Old 06-26-2007, 10:09 PM
KB440's Avatar
This was done by the PO.
I started out to repair the steering coupler on the truck yesterday, after taking the rag joint apart I got to the coupler. After cleaning the grease off I became The metal retainer was loose, so I pulled it back with the rubber cover, it was welded on both sides of the coupler so you can't take it apart. Nothing but a chunk of garbage. I don't think there is the there is much if any shoes left in there, it is very loose.
OK here is a pic for a good laugh
Old 06-26-2007, 10:19 PM
Micaiahfied's Avatar
well i guess that's a good excuse to get the borgeson shaft, lol, don't like to see a hack job like that on something as important as steering!
Old 06-27-2007, 12:51 AM
BearKiller's Avatar
I recently was shown a very well built home-made U-joint shaft.
A Second Gen. U-joint shaft is a perfect slide-on fit over the First Gen. shaft, and already has a slip-yoke made in.
He removed the bottom mess from the 1st Gen. shaft and sleeved the 2nd Gen. shaft over it, then welded around the two, once he had located things where they needed to be.
Some filing was necessary to get the bottom end to spline up with the steering gear spline.
It looked as good as any storebought shaft that I have seen.
Old 06-27-2007, 01:09 AM
Muted User
LOGAN's Avatar
kevin would you expect any less from that old beast, look at the guys that owned it before you, they used the poor thing for towing a bobcat most of its life. glad it didnt break on ya man.
Old 06-27-2007, 07:54 AM
BRUISER's Avatar
did it look like this when done??
Old 06-27-2007, 05:56 PM
Originally Posted by KB440
That's nasty!
Old 06-27-2007, 06:34 PM
BearKiller's Avatar
Not really.
He actually slid the 2nd Gen. shaft over the 1st Gen. shaft and used the 2nd Gen. slip-yoke.
The 2nd Gen. shaft is hollow.
He did no welding at the steering-gear end.
Old 06-27-2007, 07:20 PM
1st Generation Admin
BC847's Avatar
A little Bondo would have fixed it right up.
Old 06-27-2007, 08:44 PM
KB440's Avatar
That's the problem, I think the brake cleaner ate the bondo
edwinsmith's Avatar
Received 1,038 Likes on 763 Posts
Don't forget the JB-Weld and the Duck-Tape.
Old 06-27-2007, 10:29 PM
Exekiel69's Avatar
Wow, somebody doesn't like running to the autoparts store.
The_Head
09-24-2010 09:39 AM
One Tree
05-23-2006 07:38 PM
TurboAZ
06-15-2005 10:33 AM
redhornet
05-24-2005 10:02 AM
eng208
03-22-2004 11:41 PM
Quick Reply: How not to fix your steering coupler
