Not Enough Timing?
Old 01-11-2004, 02:54 PM
signature600's Avatar
Not Enough Timing?
I just had my truck timed (finally) and it idles a lot smoother, but it still white smokes a lot after startup and whenever you pull away from a stop light or after sitting for 2-3 minutes. I think it was timed to factory specs, even though I wanted to go to about 16-16.5. Does it need more?
Old 01-11-2004, 06:13 PM
Jim Fulmer's Avatar
Yes
Old 01-12-2004, 08:47 AM
Thanks, Now I'll have to talk dad into getting it back to the shop!!??
Old 01-12-2004, 10:47 AM
Jim Fulmer's Avatar
The next time you time it make sure the shaft is clean before installing everything and put a new lock washer on it.....there just a few dollars. I will usually only reuse them once depending on how they look.
Jim
82F100SWB
11-14-2013 07:05 PM
Boatnik
08-05-2007 09:09 PM
RDABIKE
06-13-2003 11:26 AM
Lance
05-31-2003 06:44 PM
Quick Reply: Not Enough Timing?
