normal temp for egt gauge
Old 07-18-2010, 05:07 PM
chadwick's Avatar
i got done installing my egt gauge and i went and drove around for awhile. The gauge barely broke 200. I am just wondering what everybodys normal temps are.
Old 07-18-2010, 06:35 PM
Mike L's Avatar
I just installed an Edge and my egt, at a warmed up idle, is around 295 to 300 deg. I am amazed at how fast the temps rise and fall under various driving conditions. It will climb up to 900 deg in a heartbeat - just getting up to hwy speed. Double check your install - something doesn't sound quite right.
Cheers!
Mike
Old 07-18-2010, 07:53 PM
DodgenIt's Avatar
Barely broke 200 for all the driving?
Yea something isnt right. Normal driving for me is between 500 and 1100 depending on everything.
But even with my truck in park at idle its around 240*.
Old 07-19-2010, 01:58 AM
Dinner's Avatar
Did you install it post or pre turbo? Also, where did you hook up your connections? Varies truck to truck but certain electrical noise will screw up the gauge. Heck when I K up my CB, my egt gauge falls to 0..still need to re-wire the CB to the battery...
Old 07-23-2010, 08:45 AM
cmed250f's Avatar
at 60 mph that around 2000rpm in my truck im running at just under 700*. at idle after driving she is at 400 and drops from there the longer i sit. climbing a hill with comp box on 5 i can get up to 1200*. I installed mine in that back plate on the manifold easiest place to do it and gets reading of the hottest cylinder #6
Old 07-24-2010, 07:36 PM
KATOOM's Avatar
Somethings wrong. How and where did you mount?
triton1
10-09-2009 12:00 PM
Ghost Ram
12-03-2006 08:57 PM
Dieseldirt
10-01-2006 03:23 PM
jmd025
12-14-2005 07:58 PM
cLAYH
10-07-2004 11:29 PM
Quick Reply: normal temp for egt gauge
