Is this normal?
Old 01-14-2007, 10:26 PM
solfish's Avatar
Is this normal?
I just bought a 1998 12V and drove it home from Arizona. I don't know if this is normal, but when the turbo starts cranking the air flow through the A/C vents start to blow harder. Is this possible? I couln't find any similair isuues in the forum. Thanks
Old 01-14-2007, 11:13 PM
mr T's Avatar
what?.. the more turbo=more flow through vents?...what kind of air? hot/cold?
Old 01-15-2007, 05:13 AM
swmnkdinthervr's Avatar
That phenomenon is pretty commom in vehicles that you have either or: a generator, nominal alternator output, a charging system that is almost worn out, or you have every accessory in the vehicle on...so it could be quite normal
Old 01-15-2007, 10:18 AM
solfish's Avatar
With just the fan on the air flow just increases with no air temp change.
Old 01-15-2007, 10:26 AM
infidel's Avatar
What's your voltmeter doing when this happens?
Old 01-15-2007, 10:34 AM
solfish's Avatar
No noticable change on the guage.
Old 01-15-2007, 01:22 PM
solfish's Avatar
Seems like it's blowing out of the defrost vents.
Old 01-15-2007, 04:44 PM
infidel's Avatar
The vents default to defrost when there is little or no vacuum. Could be it just sounds like the blower is turning faster in the defrost mode.
I would suspect you have a vacuum leak somewhere.
Old 01-15-2007, 05:18 PM
TIMMY22's Avatar
sounds like my 1964 international 424. the more RPM you give it, the brighter the lights are.
bigbaddiesel
03-22-2003 07:52 AM
prozack
02-04-2003 05:51 PM
Poor_Furd_Owner
01-07-2003 04:21 PM
mountainoiler
01-06-2003 06:58 PM
tobyw
12-11-2002 11:54 AM
Quick Reply: Is this normal?
