No Turn signals
No Turn signals
I will try to keep this short. I just replaced the heater core in under four hours. everything works except the turn signals. The hazards work, Brake lights work. windsheild wipers work. highbeams work. but no turn signals. I also can not find any blown fuses. Could I have pulled a ground loose or something like that. Help me find out where I went wrong before I get pulled over for no turnsignals.
If you activate them, do they come on, but no flash?
Switch you hazard and turn signal flasher and check.
If not, then it is time to start checking connections, I assume you rolled the dash back or removed it?
Sky-dogg
04-05-2004 02:26 PM
