No tachometer, No charging, No shifting
Old 09-21-2011, 02:24 PM
OFFDUTYEXPEDITOR's Avatar
Help!! My tachometer on my 97 3500 has been erratic for the past couple of months. Yesterday it quit working altogether and stays at 0. I have no higher gears in the automatic tranny and altimeter shows it is not charging. Any help would be most appreciated.
Old 09-21-2011, 04:43 PM
patdaly's Avatar
First thing, next to the oil fill tube will be the connector for the engine speed sensor, check it for corrosion and clean it good. Oftentimes it gets gunked up and it loses the signal. Use either contact cleaner or brake cleaner, dry it well and put it back together.
If that doesn't do it, then it may be time for an ESS, or find the break in the wire.
Old 09-24-2011, 08:13 PM
Thanks. Tried cleaning the old one to no avail. Put the new one on today and it works great.
Diesel-Dan
20
09-22-2019 09:34 PM
GLHS
02-25-2011 10:12 PM
Smokin96_12v
01-21-2010 01:06 PM
Brendan
10-17-2007 11:12 AM
98 Ram 24V
12-24-2005 10:19 AM
Quick Reply: No tachometer, No charging, No shifting
