No stereo after recall
Old 01-05-2008, 07:25 PM
SR71's Avatar
So the wife took the truck down to get the G30 recall done and a lube job. Now the stereo will not turn on. I do have an aftermarket deck, amps and speakers but it is just an adapter the deck plugs into to get its power. When they do the computer flash or update or whatever you want to call it is it possible that is whats causing the problem?
Old 01-05-2008, 10:40 PM
Roperteacher's Avatar
I put an aftermarket stereo in my 06 5.9 and they had to completely wire the system to "Fool" the computer!!! I can't believe how computerized these things are!!
Old 01-06-2008, 03:59 AM
hatchy's Avatar
Did you get a canbus adapter to get acc power to your headunit, or did you run new wires?
Old 01-06-2008, 10:26 AM
SR71's Avatar
A stereo shop did all the work and they installed an adapter that plugs into the factory harness. I assume that is the canbus adapter you mentioned.
beandrew
03-03-2007 01:56 PM
PMMHDP17
13
01-02-2007 04:14 PM
Ramified5.9
24
10-22-2006 12:44 AM
eightball
10-18-2006 12:13 PM
silverramer
15
03-12-2004 08:04 AM
Quick Reply: No stereo after recall
