NO power on highway 62mph max
Old 11-21-2006, 04:17 AM
bostongsx's Avatar
I have a 94 3500 ctd with an auto tranny. All of a sudden the truck is doggy around town and I cant get any speed out of it on the highway. What should I check.
Herb
Old 11-21-2006, 06:45 AM
Forrest Nearing's Avatar
is it black smoking at all? if not, check the AFC on the injection pump... either a broken signal line from the manifold to the AFC or a torn AFC diaphragm.
if it's black smoking, look for leaks at the intercooler boots
Old 11-21-2006, 09:00 AM
bostongsx's Avatar
No smoke so ill check that AFC
Old 11-21-2006, 09:26 AM
funcruise's Avatar
When was the fuel filter changed last??
Old 11-21-2006, 10:23 AM
TxDiesel007's Avatar
My money is on the AFC as forrest said...
Rick
Old 11-21-2006, 11:47 AM
bostongsx's Avatar
Not sure on the fuel filter but it looks pretty new, I dont think it is a filter issue as it was a sudden and drastic change. Could someone tell me exactly what I am looking for or how to test it as far as the afc goes. I am a diesel newbie, but have plenty of mechanical experience.
Herb
Old 11-21-2006, 12:33 PM
gmctd's Avatar
Wastegate diaphragm ruptured?
Old 11-21-2006, 02:11 PM
that would just cause higher boost... he's suffering from a lack of fuel. AFC isn't able to compress the spring and allow the lever arm to travel forward.
Old 11-21-2006, 04:47 PM
dslpower's Avatar
On the early 94's the wastegate line starts at the AFC connection. So its possible the diaphram ruptured and is dumping the boost signal pressure. On my 95 w/g line starts on compressor housing.
Old 11-21-2006, 05:04 PM
ahh, good call! I forgot about that!
Old 11-21-2006, 07:41 PM
Mainemike100's Avatar
my vote
My vote is either fuel filter plugged, or fuel gelled if temp is low, got down to 20 degrees here last night. Wastegate is also a real possible problem. Good luck and let us know what it was...
RiataAg
09-25-2013 05:11 PM
Dually Driver
13
11-13-2007 09:10 PM
belfert
09-09-2004 03:23 PM
fishin fever
02-22-2004 08:32 PM
Zino
08-15-2003 10:14 PM
Quick Reply: NO power on highway 62mph max
