No Plate, No Afc, No Extra Power
I would then say you have a filter system problem. There are many good posts on fuel system leaks and suggestion for clogs or restrictions.. I will have to search and see myself.
un hook the fuel line near the pump and run some fuel through it< app 2 gal>to make sure flow is not restricted someware you are not aware of like a partly pluged line or a cloged tank filter/screen .
i worked on hydralics for a while and saw fittings that were not drilled through all the way and blocked / restricted flow ???
also make sure wire to pump carries required ampes or pump may run slow !
rockrunner
03-05-2007 03:44 PM
johnsjas
20
09-29-2005 10:52 PM
royta
02-15-2005 10:15 PM
