no oil pressure
no oil pressure
i just bought a 1998 dct 12 valve with 280,000 miles and the oil pressure gauge will drop to zero and the check gauges light pops on. it does this when i am driving at normal speeds. i hope this is just the gauge and not the oil pump. has anyone else had similar problems? any help would be appreciated.
Bought new:
2006 CTD, Quad Cab, 4x4, 6 speed manual, dually
Jacobs exhaust brake
B & W turn over hitch w/ Prodigy brake controller
51,xxx miles
Just bought:
1998 12v CTD, regular cab, 5 speed manual, 2wd, dually
With 9’ stihl walk in tool box
Towing:
20’ flat bed Mid Atlantic Gooseneck with hydraulic dump bed
14’ Easy Dumper
18’ tilt back flatbed
For fun:
1995 Jeep Wrangler w/ 33” baja claws
Lots of mods set up for the mtns
2003 Yamaha big bear w/ 29” tires
1982 jeep wagoner aka the “War Wagon” it goes anywhere and doesn’t matter what happens to it. 35” BFG soon to be 37” swampers
Bought new:
51,xxx miles
Just bought:
Towing:
14’ Easy Dumper
For fun:
No oil pressure
I have the same loss of oil pressure problem, it happens on panic stops, bumpy road and slowing to a stop. My problem has been on going since the truck was new ( 98 12 valve Ram 2500) Dodge told me there was nothing wrong with the thing and replaced the pressure sender. I have installed a direct reading guage and it reads the pressure drop also. I am about to change oil pick up tube in the pan cause I heard somewhere they have a problem with cracks. If that don't work I guess I will go after the relief valve then the oil pump. Any suggestions out there??
Jack
Jack
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
streetsmoker
02-22-2006 06:47 PM
bigragu
01-24-2006 11:16 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
