No oil pressure on startup
Old 11-03-2009, 07:00 PM
crackcorn's Avatar
Any advice appreciated on this one. Twice now on seperate occasions I have had 0 oil pressure on startup. Gauge check light comes on. Truck runs fine and has oil pressure just the gauge isn't working. Code comes up as oil pressure sensor. If I restart truck each time it has returned to normal.
Is it common for the oil sensor to go bad on these 5.9's? Batteries are getting old, could a bad ground or low bats cause this?
Hopefully someone can point me in the right direction for diagnosis.
about 96,000 miles on the truck so far.
thanks in advance.
Old 11-03-2009, 07:33 PM
krh
krh's Avatar
check your battery voltage to insure you've got 12ish. Im sure you do or you'd have pointed out slow cranking. check wires, a reading of zero may just broken or rubbed through wire. Run a test light across all your fuses. I doubt its got a fuse for it but its a free test. If your sure its got oil pressure and the ecm is saying the switch is bad, and you cant find any cuts in the wiring or corrosion in the connectors I bet you the ecm is right.
and your sure you've got oil pressure right? Its not something getting sucked up against your pickup line then falling off when you shut it down and restart.
Old 11-03-2009, 11:40 PM
crackcorn's Avatar
Thanks for the help krh. Time for me to dust off the old Fluke and electrical tools and go dirty wire divin'. I'm thinking it must be electrical or the sensor is bad. It has been random, so I hope its not something blocking the intake line... Can't imagine that would be the case as I change oil more then regular and only use quality WIX or Baldwin filters. I'll post when I find the issue in case someone else runs into the same symptoms.
Old 11-04-2009, 02:30 PM
rich's Avatar
put a mechanical gauge off the turbo to check it the sending units on these trucks go by pressure not number you could have 15# to 60 # gauge isnt always right
Old 11-04-2009, 07:02 PM
krh
krh's Avatar
Ya, i doubt theres anything getting in the way. Ive just seen guys pull transmissions out of cats twice because of forgotten rags. Let us know what you find out.
derceg
03-30-2011 12:35 AM
Mt Hydro
03-18-2011 05:02 PM
high bid
10-12-2007 02:44 PM
gkainz
11-09-2003 07:26 PM
Quick Reply: No oil pressure on startup
