no oil pres after very cold start.
Old 11-21-2011, 09:52 PM
Marty baum's Avatar
I went to start my 1994 2500 this morning in the Alaskan interior (-43 F). It run for about 10 - 15 sec and never developed an indicated oil pressure. I shut down and put a 300 watt magnetic heater on the oil pan and left it all day. I came home after work ( it warmed up a lot it was only -29 F) and tried again, still no oil pressure. Could the thick oil have broken something, or is the 300 watt heater not enough?
Old 11-21-2011, 09:57 PM
Purplezr2's Avatar
Try a manual gauge. There is a port on the filter head, may take two people. One to start the truck and on to look at the gage. The oil be to thick to suck up.
Old 11-21-2011, 10:01 PM
Tate's Avatar
What oil are you running? It could very well be a bad oil pressure sender. The sending unit is the off the cam gallery, which is the last place to get pressurized oil, so it takes time. Granted, we're not to -40 temps yet, but we are in the mid -20C temps, and it still takes about 5 seconds to oil pressure registering. If you're truly concerned, I'd pick up a cheap oil pressure gauge and mount it on the filter head to see if you're getting oil there or not.
Old 11-21-2011, 10:06 PM
Marty baum's Avatar
I'm running Mobil 1 fully synthetic 15/40. How long is it safe to run it with no indicated pressure?
SCtinman
12-20-2007 10:12 PM
Thedieselkid
12-19-2007 03:01 PM
rcurrier44
07-15-2007 04:17 PM
yukon mike
11-28-2006 10:51 AM
Barry Smith
11-14-2004 09:56 PM
Quick Reply: no oil pres after very cold start.
