no mpg
Old 03-22-2009, 09:09 PM
cabtruck's Avatar
no mpg
I have a 06 truck auto trans and get around 17 to 18 mpg one of my frends has a 04 his truck wount get over 13 to 14 mpg what could be wrong hith his truck it has been to dodge they cant find anything wrong
Old 03-23-2009, 04:59 AM
sabersix's Avatar
Could be different gearing (e.g. 4.10 vs 3.73) in the rear. Probably the problem is attached to the ankle of his right leg. Driving style has a lot to do with the miles per gallon a driver sees.
Switch trucks for a few tank fulls and see what happens.
Old 03-23-2009, 04:45 PM
cabtruck's Avatar
same gear i have drove both trucks i get the same 13 to 14 he drives mine gets 17 to 18 it is something in the truck
Old 03-23-2009, 05:56 PM
sabersix's Avatar
Are you using the overhead mpg readout as the basis of your comparison? If so, there may be some inaccuracy in that reading. Does one truck have bigger tires? Have you compared hand-calculated mpg figures?
Just throwing stuff out here. Obviously, it could be a lot of things.
Old 03-23-2009, 08:39 PM
cabtruck's Avatar
the only things different his ts 2 wheel drive mine is 4 wheel drive and the year so the 2 wheel should get beter then the 4 wheel drive ?
Old 03-24-2009, 05:23 AM
sabersix's Avatar
Yes, from most reports I've read, two wheel drive typically gets 2-3 mpg better than 4-wheel drive.
Old 03-24-2009, 06:00 AM
Administrator/Jarhead
madhat's Avatar
Hand calculate a few tanks, see what you get. The overhead liar is usually off anywhere from 2-7 MPG...
Old 03-24-2009, 08:22 AM
cabtruck's Avatar
i am not using the over head and a 2 wheel drive shoud get beter then a 4wheel drive so why is it geting 4 to 5 mpg less then a 4 wheel
Old 03-24-2009, 08:33 AM
madhat's Avatar
Could be any number of things.
Is he using the overhead?
Bad injector?
Driving habits?
Idle time?
Someone's stealing his fuel?
Codes?
Old 03-24-2009, 04:49 PM
cabtruck's Avatar
Bad injector?
Driving habits?
Idle time?
Codes?
not useing the overhead i cant get any better mpg no more idle time no one stealing fuel no codes have not checked injectors
bngcustoms
45
06-20-2009 06:55 PM
richard
26
09-06-2007 01:35 PM
bigfish5
09-19-2006 12:56 AM
Maddog
01-03-2003 10:01 AM
rshelton88
15
12-22-2002 09:40 PM
Quick Reply: no mpg
