No interior lights
No interior lights
I have checked all the fuses and they are all good. But the lights do not come on with the doors open and you can't turn the map lights on. Also the little light ring around the ignition does not glow any more. Secondly when you turn the headlamps on the radio does not dim, nor does the factory radio harness send power to the radio.
So I am thinking the harness under the dash is going bad in sections. Any ideas?
You missed a blown fuse. Buy a fuse checker from the autoparts that you can check fuses without removing them. They're under $10.
Sometimes you can miss a blown fuse just by looking.
Also don't forget the underhood fuse box.
naaaa, I have one of them with a bad circuit. My 97 has the same problem. The circuit goes to a fuse by the drivers door and then to a 50 amp fuse in the under hood box. Mine has lost continuenty between the fuses. I have not gotten around to it but will run a new wire between. I miss my inyterior lights. I have spent house diagnsing the problem. I can run a clip wire to the fuse from a hot point and all works well, so the wire is burned out or not making contact.
ehammett
13
12-30-2008 05:20 PM
proudpapa97
05-04-2008 06:50 PM
Vintage Empire
12-20-2005 10:02 AM
patriot pearl blue
12-29-2004 06:47 AM
CHarlan
08-06-2003 08:40 PM
