No fuel pressure at filter but still runs
Old 04-20-2007, 11:27 AM
silverdodge04.5's Avatar
My 1995 has no fuel pressure at the fuel filter outlet when checked with a gauge. The motor runs but lacks power and wont rev past 1800 rpm. Is this a lift pump issue? Just installed a new fuel filter. I didnt think the engine would even run with zero fuel pressure. Any thoughts would be welcome.
Old 04-20-2007, 11:40 AM
John Faughn's Avatar
It may be the overflow valve , thats where the pressure is set , by the valve spring restricting the flow to the right pressure , My guess is whats happing is that you have fuel from the lift pump , but not pressure from the overflow valve , after a new OFV , check pressure again , the lift pump could be weak also .
Old 04-20-2007, 12:32 PM
I should have mentioned that I also replaced the overflow valve.
Old 04-20-2007, 03:31 PM
Fule filter , then lift pump .
Forgot about an other comin issue , the fuel line & or hoses coming from the tank can leak , but since its a vacume [ the pumps suction side ] you may not see fuel , so putting about 3lbs air pressure in fuel tank then look for fuel leaks in lines & hoses from tank to lift pump .
Old 04-20-2007, 04:43 PM
Thanks for the suggestions--I got a lift pump and a prefilter kit to put on tommorrow. I will pressurize the tank and get new lines if needed.
ppsi
11-05-2013 07:12 AM
rams2500
03-14-2010 11:18 PM
OldDodgeOwner
09-01-2009 11:42 AM
88xjwheeler
04-22-2008 08:56 AM
abc4yew
03-29-2008 08:37 AM
Quick Reply: No fuel pressure at filter but still runs
