No dashboard lights
Old 12-06-2006, 10:38 PM
Baja's Avatar
No dashboard lights
My dash lights went out a while ago. The headlights and dome light work, just the dash is out. I replaced the switch (thanks for the help Clutch1) but no change at all. I checked the fuses, and they all are OK. What is next? I am not the best electrician, so I need some help. Thanks in advance.
Old 12-07-2006, 05:20 AM
atthepark's Avatar
check for ground
You might want to check and make sure you havent lost the ground in the dash light wiring. There is also a recall on the light switch and wiring harness. Just some thoughts.
Anthony
Old 12-07-2006, 06:45 AM
Conn's Avatar
are your running lamps (park lights) working as well?
Old 12-07-2006, 09:52 AM
Baja's Avatar
The running/parking lights work.
I have a vague memory of looking up the recall, and if I remember right, the recall did not cover the 96 2500 diesel.
Where is the ground located?
dodgedude361
01-30-2011 05:12 PM
DU.DP.
02-06-2009 10:30 PM
Baja
10-19-2006 05:19 PM
Dieselcamper
11-09-2005 12:13 PM
Quick Reply: No dashboard lights
