NO CRUISE P1683 code!
Old 03-09-2010, 08:03 AM
br4x4's Avatar
Hello to all, i have had no cruise control for months and have tried to fix it many times but no luck. my Snapon scanner says code P 1683. i replaced switch and clockspring and heated air soloniods , checked all wires i could see.
anyone have any ideas as to where i should look?.
1996 Dodge Ram Cummins, 4x4, 128000 miles, auto trans.
Old 03-09-2010, 08:15 AM
johnh's Avatar
i had a '92 that kept blowing fuses,i never could find the reason so i put in a 30 amp..........end of problem
Old 03-09-2010, 08:24 AM
gcdodge's Avatar
Cruise control is run by vacuum check your vacuum lines Does everything else work 4x4 does heat come out of all vent or just defrost vents?
Old 03-09-2010, 01:20 PM
br4x4's Avatar
Heater works , the vents work , 4x4 works , i have great vacuum pressure.
all relays and soleniods switch when the scanner does them.
Old 03-09-2010, 01:21 PM
br4x4's Avatar
all fuses are good checked them out again yesterday.
Old 03-09-2010, 04:13 PM
infidel's Avatar
Unless you spent $1200 from Chrysler for DRB software for your scanner doubt if it's reading right.
The common OBD system doesn't start until '97.
Most common causes of no cruise are a rotted vacuum hose under the battery or a bad brake light switch. Since the switch is only $11 from Napa I find it easier to just swap in a new switch rather than test the old one.
Old 03-10-2010, 03:03 PM
br4x4's Avatar
i am not getting any volts at the stop light switch. brake lights are fine.
i will replace switch today and go from there.
Old 03-10-2010, 03:33 PM
br4x4's Avatar
I checked the servo by pulling battery and checked lines and wires, looks fine
no battery acid, no cracked lines.
Old 03-13-2010, 01:34 PM
br4x4's Avatar
I checked the brake light switch today and it is working right. and i have the little green light on the switch on the steering wheel coming on. so what should i check next?.
Old 03-14-2010, 10:40 AM
infidel's Avatar
If the brake light only works right sometimes just replace it for $11.
Old 03-14-2010, 12:43 PM
br4x4's Avatar
The switch is working. what i think is the problem is the computer. P1683 says S/C power relay circuit. the computer controls the speed control. i checked
the servo wires and they are good. all vacuum lines are fine. i am not 100% sure about the computer being bad. would like to fix it myself before going to ***********.
O.T
09-06-2007 06:10 PM
trophystock
07-06-2006 06:28 PM
Terraizer
12-14-2005 03:56 PM
CTD NUT
04-05-2005 04:45 PM
DF5152
02-10-2004 10:33 PM
Quick Reply: NO CRUISE P1683 code!
