No Brake pedal
Old 05-28-2010, 07:24 PM
Roadmedic's Avatar
No Brake pedal
Just finished changing the brakes on the front of the truck at 434,000.
Changed Rotors, Calipers and pads.
Changed the wheel bearing on the drivers side.
Bled the brakes and pedal was fine.
Started the truck for the test drive and there is no pedal. Have bled the system several times. No air, just fluid.
Any ideas?
Old 05-29-2010, 09:02 AM
Fordzilla's Avatar
You have trapped air in the system...Use your pressure bleeder backwards starting from the farthest bleeder screw in sequence working forward toward the M/C...This will force the air into the reservoir......Ben
Old 05-29-2010, 09:25 AM
Spooler's Avatar
Did you put the calipers on the correct sides? The bleed screw on the calipers will be on the top. If they are on the bottom then this is your problem. I have seen this mistake made a couple of times.
Old 05-29-2010, 03:58 PM
Roadmedic's Avatar
Really wish you had posted faster. Bled them many times today and out of desparation had my wife sign on and see if anyone had posted.
After she read it to me, it dawned quickly that the back ones were up and the fronts were down.
Thanks for your help. They work wonderfully now.
Old 05-29-2010, 08:56 PM
Spooler's Avatar
Seen it many times before.... At least you weren't a certified mechanic.... Got a free lunch off of this help too....LOL... Must of been a brain cloud.... Can't get the air out unless the bleed screw is at the top.
Old 05-29-2010, 09:23 PM
Roadmedic's Avatar
Only get paid what I think I am worth. Today and last night, I think I should have worked for free.
The sun was hot, I was parched, dirty and hungry. Left the truck and borrowed friends little pickup. Went and got more fluid this morning and started at 7:30 am.
I knew there was something I had to have done wrong.
I had two friends come by and we worked most of the day.
Called my wife and when she read it, I asked again. This was at 2 in the afternoon.
We all felt like fools.
1 hour later, done.
The only plus side, is when changing them through the day, I noticed the left axle u joint was bad again for the third time. Just went ahead and fixed it.
reaves11
02-10-2013 02:29 PM
Diesel Jeff
07-05-2009 05:56 PM
600 Megawatts
03-26-2008 07:09 PM
93w250
12-08-2002 08:00 AM
crossy
11-10-2002 12:02 AM
Quick Reply: No Brake pedal
