No 4WD light in dash
Old 08-01-2005, 10:18 AM
Bobcat698's Avatar
Question No 4WD light in dash
I had 2 lights in my dash "burn out".. Low fuel and the 4WD light.
I replaced the low fuel light and the 4wd light.. Only the low fuel light comes on when you turn the key on and all the lights glow.. I tried the low fuel bulb in the 4WD spot but it still won't work..
ANY ideas??
Thanks!
Old 08-01-2005, 12:15 PM
13FOX's Avatar
Does the 4WD work? If so check on the right side of the frame right by the ac compressor to see if a piece of the fan belt hasn't cut through those two wires. I had this happen to me when I threw a fan belt and the 4WD light wouldn't come on for this reason. Only thing a can think of right now.
Old 08-01-2005, 12:41 PM
Bobcat698's Avatar
The wires did get disconnected.. but I cut the connector off and reconnected it using a wire splice.
4WD works fine.
Shouldn't it illuminate when you turn the key on to test?
Old 08-01-2005, 12:59 PM
TxDiesel007's Avatar
Bobcat
solve your problems and go posilock.. the 4wd indicator works all the time when u engage the lil thingy, and no vac actuator failiures no more....
Good luck my friend!
Tx
Old 08-01-2005, 02:56 PM
Bobcat698's Avatar
4WD works FINE on my truck.. the light doesn't show up thats all
What kinda $$$ are we talking about with a posiloc??
Old 08-01-2005, 03:07 PM
Check your PMs
what it usually is, remove the connector and blow it out, that is what i did with mine previously, and it worked just fine, it is probably just got dirt or mudd in it from wheelin.check both connections, maybe one is grounding out...
Tx
Old 08-01-2005, 03:48 PM
Bobcat698's Avatar
I'm more worried about the light not coming on when ALL the lights illuminate in the dash when you turn the key on. I know at one time the light did work.
p0wd3rp1l0t
06-27-2012 10:29 PM
NoSparkplugs
17
05-17-2009 10:36 PM
MoparMarv
04-21-2006 12:43 PM
1320
05-06-2003 06:30 PM
Quick Reply: No 4WD light in dash
