Next Mod Suggestions
Old 01-08-2007, 06:09 PM
Patriot2500's Avatar
Wondering what my next mod should be. I want to do something else to make a little more power but am not sure. Truck right now as 5"exhaust, AFE Stage II, BD Power Pup with Crazy Larry, ATS manifold. I'm sure some of you will suggest trans, but I don't have the $$$ right now to do that. Besides, I really don't drive the truck hard all the time because it is my DD and my business vehicle. The cheaper, the better. Thanks in advance.
EDIT: I have searched for this and haven't gotten a definite answer. What would be the best box to stack with my BullyDog Power Pup with Crazy Larry? I run the chip everyday on the performance setting.
Old 01-08-2007, 06:27 PM
White97GTVert's Avatar
Maybe not a full tranny but at the minimum a VB and TC.
There is no point to stacking anything on that truck until the tranny can put it to the ground.
You will also end up needing a flex-plate I imagine.
If you choose to go ahead and stack your truck the TST has been talked about with good results when using the Crazy Larry. I just think its pointless to go further with any more power until you get a little done to your tranny.
Its also about Turbo Time for you as well.
Old 01-09-2007, 06:42 AM
Thanks, I figured that should be the next step. Anyone else?
Old 01-09-2007, 10:27 AM
morkable's Avatar
Thats about the size of it, you need some tranny work first. After you get tranny work, get a HOT Juice, works very well with downloaders. And a turbo
Kevin
hallio217
13
10-29-2015 10:39 PM
MegaMagoo3500
ABDTR #5
46
12-30-2007 07:16 AM
jmccart
12-19-2007 12:49 AM
2500Diesel
12-04-2006 06:34 AM
Quick Reply: Next Mod Suggestions
