Newer seats on a 92 ram 250 ?
Old 07-18-2011, 02:41 PM
Justin erler's Avatar
Is it har to modify a newer seat with a center consul that folds down to my first gen it's a 92 le with the normal bench seat and I want the two bucket seats with the center consil that is also a seat
Old 07-18-2011, 06:21 PM
lovin1stgens's Avatar
heck yes! i got seats from a 94 in my 93. as long as the seat will fit between the doors, she'll go in.
if i was you, i would weld new metal onto the new seat, so you can use the stock holes in the floorboards.
if its a standard cab you wont be able to lay em back, but what else is new lol
Old 07-20-2011, 10:27 AM
enydick's Avatar
i'd go with 2001 quad cab seats belt built in to seats
Old 07-20-2011, 02:40 PM
DPFservice's Avatar
I went with the 2000 front seat with built in seat belts and center console. I think I paid $250 at a junk yard. Has drIverside electric controls. Pretty easy to install if you have a welder to make a frame for it.
Old 07-20-2011, 10:51 PM
bryson711's Avatar
There is a great post in the sticky to show you how to build a frame to put the second gen seats in a first gen, it even has a blueprint to build a frame
Old 07-20-2011, 11:09 PM
Received 1,331 Likes on 862 Posts
That was my write up..... It was in my crewcab, but should be very similar in a reg or ext cab set-up.
Old 08-15-2011, 10:21 AM
frame for seat conversion
thanks guys..... where would i fiind that post that shows how to build that frame?
Old 08-15-2011, 10:30 AM
The Big Dodge's Avatar
Watch using the newer 2nd gen seats they require power to release the belts that are built in to the back rest. Its a simple fix to run switched power to release them.
Old 08-15-2011, 11:45 AM
DPFservice's Avatar
I have the 2000 seats with the seatbelts built in and have power to them not hard to do
Greed 93
01-31-2010 09:26 PM
smoky beast
02-26-2007 09:17 AM
philobeddo
06-15-2006 06:16 PM
guh2stroke
12-24-2005 08:45 PM
NoSparkplugs
10-10-2005 09:19 PM
Quick Reply: Newer seats on a 92 ram 250 ?
