View Full Version : newbie to the wmo
ol' 93 12 valve
09-02-2008, 11:17 AM
I have the hook up on waste motor oil, gear oil, transmission fluid. I have a few concerns. Im pretty sure there is some antifreeze in some of it, is there a filter that will filter it out? And there are a bunch of diiferent types of oils like 5w30, 15w40, synthetics, synthetic blends will these cause problems? I plan on running this in a 91 12 valve cummins and an 88 ford 7.3 idi.
thanks
MikeyB
09-02-2008, 12:02 PM
Best thing to do if it does contain water/antifreeze is to use a centrifugal filter from Dieselcraft. The OC20 with pump isn't cheap though.
http://www.fryer-to-fuel.com/store/product122.html
MikeyB
ol' 93 12 valve
09-02-2008, 03:35 PM
I planned on doing a gravity fed setup, can i still use a filter like that?
MikeyB
09-02-2008, 04:18 PM
No. Will still need a pump. The pump is need to get the pressure up around 90 psi. There's a hub inside the filter that needs to spin up to 7k rpms for the centrifuge to work.
MikeyB
catnfool
10-21-2008, 10:15 PM
if you have more time than money, you could let the antifreeze settle out and just suck out about a foot above the bottom of the tank. the antifreeze settles pretty quick in warm weather.
this is from experience, by the way;) but DO NOT run 75% at 25* F...
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
