PDA
View Full Version : Newbie Questions On Pulling
deezulsmoke
08-29-2005, 02:37 PM
I attended scheid diesel extravaganza this weekend and it was awesome. Makes me want to start participating in some of the local truck pulls. I have a 04.5' 3500 quad cab dually 4x4, you can see my mods in my signature. Anyway, I have a six speed manual, and was wondering what the best way to start out on the track is in what gear ?? Low Or HI 4x4 ?? Ect. My other concern is should I be worried about tearing my truck up participating in the street class diesel truck events ?? This is my daily driver so I can't afford to tear it up. I just think it would be a lot of fun to participate in some of the truck pulls. It seems like most guys tear things up when they start hopping at the end instead of just cutting it down and stopping. Anyway, any info. or help or suggestions would be greatly appreciated.
thanks,
matt
HOHN
08-29-2005, 02:57 PM
Pulling=carnage.
My best advice is to keep your pulling involvement to spectating. Otherwise, you'll end up spending a LOT of money on beefing things up.
jmo
95ram
08-29-2005, 03:08 PM
HOHN I'm sorry but a I have to disagree. You can brake stuff, and you will if like you said you dont back out of it when you start hopping. when you start hopping shut'er down. I've done about 10 pulls with my pickup. 3 were on the stock clutch. Haven't broke anything yet. I pulled in 4 low 3rd gear. Brought the rpm's up to about 1700-1800 and start leting the clutch out. Dont slip it to long or it will keep sliping. Once I got started I let off the throttle a little to make sure the clutch wasnt slipping and the got back on it. Try it. Have fun with it.
Kman9090
08-29-2005, 04:29 PM
Just remember YOU HAVE TO PAY TO PLAY, if you are going to pull I would be sure to keep a wad of dough in the bank just in case something does break.
ihpower
08-31-2005, 11:12 AM
just make sure you are in low range. high will get you nothing
steerjock
08-31-2005, 09:05 PM
ihpower- I dont really agree with that Ive seen quite a few pullers around my area that run 4hi in 4th gear. granted their runnin dd clutches but just like in any pull wheel speed is a factor.
just my $.02
perkins
09-01-2005, 11:19 AM
4High and 2nd trans is 11.96 with a 5 sp. finnal drive this is what most of the guys pull in with 3.54s
4hi 2nd gear in 5600 and 3.73 gears 12.61 if you put it in 4th it willbe 5.18 I don,t think it is posible.4th andlow tranfercase is 14.1 fin. 5th &low is 10.15
This is with 32in tall tires.
Dale
Kman9090
09-01-2005, 06:01 PM
I've heard of 4th in 4hi with a quad-disc clutch
TxDiesel007
09-01-2005, 06:57 PM
Whatever the case maybe
If u have money to burn and can afford to destroy a clutch, then go up to third or fourth on four high or four low, If i was gonna pull, seein that its my only ride, and i have a stock clutch, id go second and low.. end of story, what good is having so much power (not me of coarse tho) if you cannot properly put it to the ground?
Tx
deezulsmoke
09-02-2005, 11:03 PM
Are you all sure my little ol cummins has what it takes to destroy my stock clutch [coffee]
perkins
09-03-2005, 11:46 PM
If they can pull 4th and high they have alot more power than Haisley or Shieds.Or they are just pulling your leg if they have stock gears.
Dale
PourinDiesel
09-04-2005, 03:27 AM
My best advice is to get a clutch and come at around 3k rpms....
Sledpulling will empty your wallet [duhhh] [laugh]
GR8WHT
09-08-2005, 11:15 PM
I agree with 95 ram. I went to my first pull last weekend - asked a lot of questions. The one guy w/ a manual tranny stated he started in 4th gear, 4-low; brought her up to about 2k, slowly slipped the clutch for 10-20 feet, put the right foot to the floor and held on! (He had 4 full pulls, so he must have been doing something right!) He did have a dd clutch, and was pushing 550 hp/950 tq. IMO; for your setup: 4low, 2nd or 3rd, slip it a little to get'er rolling, then punch it and go! :D
