Newbie ques. on Starter Replacement
Old 11-02-2003, 01:48 PM
stojo22's Avatar
How's it goin fellas. Just had a quick question for you all. I'm helpin the Dad change the starter on the our old 94 diesel. The reason why we're changing the starter is b/c I was driving the truck one day and when I went to start the truck all it would do was click and not turn over. Then eventually it would start but I would hear something keep winding up. It sounded like the starter kept on winding up. Well when I went to shut it off it wouldn't!! I mean it kept on running until I put it in first and held the brake to kill the engine. But as I did that the starter fried. So now we have the new starter...but I was wondering if there was anything else we should change..such as the connectors to the starter....Sorry for the long post. Any help would be greatly appreciated.
Old 11-02-2003, 02:01 PM
Smokee's Avatar
Re:Newbie ques. on Starter Replacement
Are you sure that the starter fried? The problem is sticking contacts. They can be replaced.
You might want to check the fuel shut-off solenoid.
Don't buy the starter at DC. Other places are cheaper.
Old 11-02-2003, 02:19 PM
stojo22's Avatar
how can you tell if the contacts are stickin?
Old 11-02-2003, 03:21 PM
kandgo's Avatar
Hey,smokey is right, check out the starter contacts,9 out of 10 it is the problem, if so then replace with new contacts and plunger kit from www.fostertruck.com ,It is a no brainer to do,and it will save you allot of money, also he sells new starters less than cummins or dodge. goodluck,,, kandgo
checkster
09-22-2006 09:30 PM
rockyw
04-29-2006 03:11 AM
rockyw
04-21-2006 02:51 AM
luv2smoke
07-22-2005 09:04 PM
RickCJ
02-22-2005 05:45 PM
Quick Reply: Newbie ques. on Starter Replacement
