Newbie Here "05 CTD Oil Leak
Hi all, newbie here. I have a '05 CTD that every so often drops a drop of oil on the floor. My brother said it's coming out of the "slobber tube".?
I bought the truck used in Dec. abd it had 16,000 miles on it, now it has about 22,000', Is this normal ?
Ray
Ray
It very well could be... Get under it on the DRIVERS side and find the "Blow By tube".. SHould be to the left of the main engine pan.... If that area is anywhere near where you saw the solem drip thats probably what it is... Take a rag and wipe it down.. Some have zip tied socks, etc to catch the oil... LOLOL
It is absolutely normal... Theirs probably did it too but maybe they didn't catch it or something... Now a drop now and then is NORMAL, if you have a LOT coming out of there, or it is flowing out the tube and coating the under side of the truck, this is NOT normal! This means your crank case is filling up and thats how it gets out. Usually yhis will happen when an Injector sticks open and fills the crank With Diesel or if a head gasket gives way and fills the crank with coolant. A drop now and then is just fine and it is doing it's job...
Thank you, it is just a drop now and then. No oil on the back of the truck, and I believe it's after we have been on the road for a few hours.
Ray
Ray
Monty
03-10-2008 07:34 AM
PEAKSTRYDE
10-11-2007 04:20 PM
Jim Swantko
01-11-2005 07:31 AM
