New Wiring Brakes Dragging
Old 10-21-2009, 11:02 PM
tysrsx1's Avatar
I just installed trailer wiring onto my 07. Problem is that the trailer brakes are now dragging badly. The brake controller is not recognizing that there are brakes to control according to the readout on the controller. However, all trailer lights are working properly. I am using a 6pin to 7 pin adaptor, I know that these adaptors pins can be switched around, but am not sure if I need to do this. Has anyone had to do this before with an adaptor? This is really beginning to get to me......HELP!
Old 10-22-2009, 12:33 AM
CrazyCooter's Avatar
The adapter is likely your problem. There are east coast and west coast adapters. Usually the charge and brake pins are switched. If you can take it apart, you can just swap the pins back.
Old 10-22-2009, 11:52 AM
davidj54's Avatar
That's exactly what happens when you have the wrong 6-pin adapter. The power and brake wires are swapped (A & S). You can swap them or buy the correct adapter.
Old 10-22-2009, 04:12 PM
Jeff in TD's Avatar
This explains how 6 pin and 7 pins are wired, and how some 6 pins have the two switched...
http://www.etrailer.com/faq-wiring.aspx
Old 10-23-2009, 07:42 AM
DTR Advertiser
southwestwheel's Avatar
Reverse adapters were a bad idea from the drawing board. Often the hot wire and the auxiliary wire get mixed up. You still have one less wire.
Old 10-23-2009, 09:54 AM
rich's Avatar
thats why i dont use adapters every trailer i have is wired the same as any truck i get or have. but it does sound like a crossing of the a/s and the power wire
volly818
02-10-2009 06:07 AM
sdsaw
11-26-2007 11:45 PM
sdsaw
11-05-2007 11:51 AM
skwelder
11-22-2006 01:11 PM
OHFarmboy
11-21-2006 09:50 PM
Quick Reply: New Wiring Brakes Dragging
