new user need help,
Old 08-09-2010, 08:51 PM
danmad's Avatar
Question new user need help,
Owner of a dodge 2500, truck running great, shut it down, went to crank after about 15 min hard to start, but did and ran very rough, as air in system, settled down and idled smooth, but when got over 12,000 rpms, would spit and shutter,
no power, but cranks fine now but will not go over 12,000 rpms.
Old 08-09-2010, 09:15 PM
Junk Man's Avatar
1. scan for codes. 2. look for fuel leaks 3. report back. 4. don't even think about parts till you get more toward a decent diagnosis.
Old 08-10-2010, 01:46 PM
danmad's Avatar
no lights on dash, no fuel leaks. Replaced lift pump last year, pump not bad but heard I needed to do this, replaced fuel filter, but old was not restricted.
Old 08-10-2010, 02:16 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
What codes is it showing?
Do the code thing and turn the ignition on and off (without starting the engine) 3 times leaving it on the 3rd time and read the numbers displayed in the odometer.
Old 08-10-2010, 03:15 PM
danmad's Avatar
I tried but nothing but the miles shown, I turned to crank but not starting the engine three times, each time to crank then to off, and leaving ig in on position.
Old 08-10-2010, 04:38 PM
patdaly's Avatar
What year truck are we talking about? Fill out your sig line so we know what we are dealing with.
Old 08-10-2010, 06:52 PM
danmad's Avatar
1999 dodge 2500 5.9 cummins, auto, has a banks air system,
Old 08-10-2010, 07:07 PM
danmad's Avatar
I tried to check for codes but got none, if I did it correctly
_______________________________________
"mad dan"
1999 250 ext cab SLT,auto, banks air system
Old 08-10-2010, 08:30 PM
Junk Man's Avatar
I would put a scanner on it borrowed from a parts store. Key frequently doesn't mean squat. Next, check for leaks in the fuel system. Look at the hard lines and the head. Check the over flow lines and T fitting on the head. Follow the fuel lines back to the tank. If no leaks, loosen & tighten any joints that are threaded. Do you have stock LP?
Old 08-10-2010, 08:59 PM
danmad's Avatar
Yes have stock lift pump. I changed the pump about a year ago, just because I was told I needed to do so.
Old 08-11-2010, 08:32 AM
patdaly's Avatar
Key on/off does not work on 98/99 years, only way to get the code is from a scanner.
Old 08-11-2010, 10:04 PM
danmad's Avatar
Thanks patdaly
TheDieselMech
06-25-2013 03:47 PM
LightningMqueen
12-01-2006 04:42 AM
cumminsho2500
08-29-2003 07:10 PM
AKCTD
11-02-2002 05:57 PM
Quick Reply: new user need help,
