New tires, mileage problems
Old 10-23-2005, 04:32 PM
cstmfabman's Avatar
I just got a great deal on four new Toyo mud terrains, 265-75R16, for $50 each. I had them mounted yesterday and went on a 200 mile roadtrip, no towing. I only got 16.5 MPG, as opposed to 18.5 to 19 with the stock Michelins of the same size. I had no idea there would be a mileage decrease with the tire change. Now I am looking to dump the Toyo's and get some more Michelins Or maybe Pirelli's. What do you 2wd guys use on your rigs?
Old 10-23-2005, 06:14 PM
RickCJ's Avatar
I don't think the tires would make a 2-3 mpg differance, but why mud tires on a 2wd??
Old 10-23-2005, 07:43 PM
jfpointer's Avatar
Check the pressure, first. My Buckshot mudders have a max pressure of 50 psi; the tire shop left them at ~35 and my mileage fell 1.5 mpg. I aired them up to 45 and got most of that back.
Old 10-23-2005, 07:49 PM
crobtex's Avatar
To keep from getting stuck?
Old 10-23-2005, 08:21 PM
Tommy93w350's Avatar
Mud tires has more rolling resistence, creating more load, using more energy to maintain speed.
Old 10-24-2005, 12:46 AM
cstmfabman's Avatar
Why mud terrains? The price was way right and I've been stuck a few times. Besides, I already have a Jeep and the Boss would'nt let me have 2 4X4's
Old 10-24-2005, 12:48 AM
drew03's Avatar
i second the idea to check the pressure.
Old 10-24-2005, 08:54 AM
HOHN's Avatar
Tire pressure is always your first check for mad MPG. Always.
Then, keep in mind that those Toyo M/Ts are big, heavy, gnarly tires. They weigh probably more than any other 265/75r16 tire you can find!
Also, these Toyos are E rated, so they can handle the higher tire pressure like your stock tires. Run them up to 55F/50R and watch the MPG come back-- at least in part.
The aggressive tread does have some mpg penalty, but it shouldn't be THAT much-- certainly not when you kept the same size!
jmo
Old 10-24-2005, 09:27 AM
dodgediesel4x4's Avatar
Also keep in mind that a larger tire is going to throw off your speedo and therefore your odometer. There are a few options for fixing this. You can go to the dealer and have them change it , get a hold of a superchips programer and change it yourself, and if you're a cheap SOB like me, you can have someone drive next to you at a designated speed and see how much it will be off at different speeds. I figured my speedo is off by 10%, so I account for that when figuring out mpg.
Old 10-24-2005, 01:08 PM
phox_mulder's Avatar
Toyo mud terrains, 265-75R16. . . . with the stock Michelins of the same size.
phox
Old 10-24-2005, 01:27 PM
Man, I'm not on the ball today ! Its Monday, give me a break Phox!!
Old 10-24-2005, 07:42 PM
Barry St John's Avatar
2 mpg is alot. My guess is air pressure. Also could be winter fuel... I'd make sure of the pressure and run a couple of tanks before I bought new tires!! They will probably not give as good mileage as the Michelins but I sure don't think it'd be 2 mpg!
Old 10-25-2005, 12:32 PM
VADSLRAM's Avatar
I switched from the original OEM Michellins to the SUV all terrain Michlies because I could stand the capacity reduction and the original traction SUXED. I could lock em up on dry road and slide like on sand. The ride got a little softer too. The big drawback on them was they needed replacing w/less the 45K miles.
Now I got a set of Goodyear Silent armor Wranglers. First thing I noticed is less rear end chirping going around lowspeed corners and less squeal on offramps. Mileage is about the same (19 city- 24/26 hwy). I'm all about traction so since I don't load my truck down much I'll live with these happily.
I did throw 2 ton of crush and run in the back to do a walkway at home. The thing squated and wobbled but I only had to go about 10 miles so no biggie.
chrisminx
07-07-2010 06:48 PM
1320
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
Captain
09-09-2005 12:16 AM
Quick Reply: New tires, mileage problems
