new to the site and ctd life
Old 07-07-2007, 04:14 AM
bigred91's Avatar
are there any fuel aditives that i need to put in with the low sulfer or just to help boost fuel milage and or performance. also what is the diff between a stock air filter and the bhaf that i have seen a bunch about. im usully good about figuring out the abreviated names for things but this site has me lost lol
Old 07-07-2007, 04:40 AM
farmer0_1's Avatar
do yourself a favor and read on the stickies about all the cures for aches and pains on these rigs. tons and tons of info. then when you get blurry eyed ask away. good to see another member.
Old 07-07-2007, 05:47 AM
BearKiller's Avatar
There are as many opinions on additives as there are members.
Here is what I do:
Winter-time = 50/50 white-bottle Power-Service and Marvel Mystery Oil, both mixed to bottle recommendations, if I remember correctly -- 12 ounces PS and 8 ounces MMO per each twenty gallons of fuel.
Summer-time = one fifteen-ounce bottle of store-brand equivalent of STP oil treatment per twenty gallons fuel.
If I have nothing else, I will dump in a quart of any old engine oil per twenty gallons.
The stock air-filter fits in the stock air-box.
BHAF is Big Honkin' Air Filter, or somesuch, depending on your ethnic upbringing .
It is something like half-again as big around, and somewhat longer, than the stock filter.
It will not fit in the stock air-box.
There are a bunch of methods to house the BHAF, including plans in the Sticky for a sheet-metal housing, and a stainless cooking pot converted into a filter-box; some simply let it lay loose, under the hood, un-protected.
Old 07-07-2007, 07:25 AM
bigred91's Avatar
i did read quite a bit of the stiky and have decided im deff gana do the power stroke ic and the stage 3 compresser but im still uncertin about the turbin side what size i should get and if i should get it with the w/g but ima do more and more reading and see what els i need to do. 2 things i looked for and didnt see were were to get a gauge pod and an intake system
Old 07-07-2007, 08:32 AM
dieselJon's Avatar
I don't know. What size is your head? J/K
Could you do us a favor. Go up to the navigation bar, click on User CP, click on Edit Signature, then write down what you have. Things that would help are Year, Tran, 4x4 or not, and size of truck, whether 250 or 350. Thanks!
Now on to the turbo side of things. The w/g one are in 14cm and 12cm. Then there are 16cm, 18cm and *gasp* the 21cm "Lagmaster" From what I read, go to 16cm or smaller is you have the 21cm that came in the 92 trucks. If you have any other year, the 12 cm is what people like to put in.
HTH
Jon
Old 07-07-2007, 12:10 PM
Remnik's Avatar
[QUOTE=dieselJon;1587545]I don't know. What size is your head? J/K
Old 07-08-2007, 10:23 AM
bigred91's Avatar
thanks for the help and my head is huge guess i need to fix the lingo.
tramp_line_ape
Introductions / New People
06-06-2008 07:17 PM
dieselbeef
06-12-2006 08:12 AM
jeffmet
11-23-2003 09:56 PM
Quick Reply: new to the site and ctd life
