New Seats???
Old 10-25-2008, 01:13 PM
bigblue1ton's Avatar
New Seats???
what is the best option for replacing the seats in these trucks mostly i want the front ones replaced the metal bar is digging into my hip on long trips i have added foam under the stock foam but it is still uncomfortable i have looked at custom seats but they seem a little out of the price range i was looking for something that looked somewhat stock while being much more comfortable
thanks in advance for any help
Old 10-27-2008, 09:30 AM
donnee's Avatar
Try contacting an upolstery shop.
They might be able to help.
Old 10-27-2008, 12:42 PM
wade234's Avatar
When you added the foam did you push the foam around the metal supports? In the posts I found they said to cut the foam just big enough to cover the existing foam and around the springs. I found that if you push it in (left and right) over the metal sides it helps a lot.
Old 10-27-2008, 08:50 PM
this is the upgrade that i did http://www.diesel-max.com/3rdgenfrontseatfix/
i put foam between the old foam and the springs
Old 10-28-2008, 11:24 AM
wade234's Avatar
That is the one I used. The first time I did it I cut the padding like the picture. The sides still hurt my legs. The second time I cut the foam wider and tucked it in the sides. If you look at picture 5 you will see the metal. Try pushing the foam in above that. More padding between legs and the metal sides. It helped my issue.
92smokin blacky
11-06-2010 10:17 PM
williamdr
13
10-20-2007 09:39 PM
jj3500
09-06-2005 06:05 PM
Boojie_00786
08-09-2004 11:48 PM
Bulldozer
02-17-2003 08:07 PM
Quick Reply: New Seats???
