new seal leaking
Old 10-27-2011, 02:21 PM
DC199512V87's Avatar
Unhappy new seal leaking
did my kdp and installed the new crank seal that came with the package. now its leaking a slow leak. please tell me its supposed to do that to lubricate the seal..... upon install i made sure the seal lip was all good and not peeled back or underneath anywhere and not damaged so not sure if this is supposed to happen......
Old 10-27-2011, 03:30 PM
oldblues's Avatar
ua o
mine has no leak in 30,000 mi with new seal !
did u install it on a dry shaft like instructions say ?
i added a drop of loctight to the seal od when i instaled it into the cover ?
Old 10-27-2011, 04:32 PM
yes installed it and the shaft totally dry like it said and used rt silicone around the od. not impressed.....
Old 10-30-2011, 10:57 AM
cromulius's Avatar
I'm pretty sure its not supposed to leak. I installed mine totally dry.
Old 10-30-2011, 11:37 AM
rebal's Avatar
it sould not leak at all eather you messed up or its a bad seal. Did you use the plastic install sleeve when you put it in? if yes you got a bad seal
Old 10-31-2011, 10:13 AM
infidel's Avatar
Could be a groove worn into the shaft where the seal rides.
Old 10-31-2011, 12:06 PM
checked for a wear groove on the shaft and didn't c any significant wear before installing the seal. musta somehow messed the seal up......
92smokin blacky
03-30-2010 06:09 PM
pwrtripls1
01-07-2008 08:55 PM
dieseljerk
07-08-2004 07:23 AM
SSV1761982
06-24-2004 11:15 AM
Quick Reply: new seal leaking
