New Power steering pump finally in!!
Old 12-13-2006, 09:47 AM
bigragu's Avatar
After extensive research on the search section, and having the local NAPA dealer remove the fitting(for free) from the shaft end of the old OEM pump and onto the reman. pump, I finally got 'er in. I flushed the entire system and after I installed a Magnefine (3/8", and cost was $22.00) filter at the return line and replaced the return line hose. The steering is now so ever smooth and best of all, that annoying purr that I have been writing about for a year is finally gone!! While the R&R is fresh in my head, I'll be glad to answer any questions you all may have if you are in need of replacing yours. You will need 2 qts. of PS fluid to flush and re-fill. Total time about 6 hours, and that is taking your sweet old time.
Old 12-13-2006, 11:09 AM
Ace
Ace's Avatar
Those Magnefines are great little gadgets. I use them on all the power steering units and my wife's transmisison has one slpiced into the trans cooler line as well. Pump will probably last forever that way as long as you replace the fluid and filter every 5 years or so.
Old 12-13-2006, 01:06 PM
Trebor's Avatar
Yup, ALWAYS install a filter. If you don't you can plan on paying for it later.
Might even be good preventative maintenance BEFORE you have to replace the box or pump.
Old 02-10-2009, 06:20 PM
D Danner's Avatar
What did you use for the return hose ,if an OEM may I ask where did you get it
tony99
04-09-2014 08:25 AM
92smokin blacky
03-30-2010 06:09 PM
DodgeCowboy
08-28-2006 08:57 PM
powerwagon440
05-25-2003 02:31 PM
amartinson
0
05-04-2003 01:55 PM
Quick Reply: New Power steering pump finally in!!
