New OFE Installed
Old 04-11-2007, 11:47 AM
Dang's Avatar
New OFE Installed
I just had a new CON OFE installed yesterday with the hydraulic upgrade and I noticed a few things that I wonder if they will change over time. The pedal is a little stiffer than before, will this ease up over time or stay that way? The gearbox seems to be a little tighter when going through the gears, will this loosen up? It wants to hop backing up, I assume that when the clutch gets set this will pass?
Old 04-11-2007, 11:54 AM
wap
wap's Avatar
I dont know if the pedal will actually ease up or not but you will get used to it and it will have seemed to of eased up.
It should get better goin into gear but no guarantees.
After the clutch is broken in very, very well try and second or third gear launch and see if that helps with the backing up/jerkyness issue.
And congrats on the new clutch.
Old 04-11-2007, 12:18 PM
dodgezilla04's Avatar
My ofe was very jerky in reverse and second when new. it is because you are used to the stock clutch allowing slippage when engaging, the iron material on the ofe, wants to grab and go. use alittle more throttle when backing, it should smooth it out some, and it will get better when broken in.
Old 04-13-2007, 10:20 AM
Dang's Avatar
OK, after driving it for a few days, I have noticed another little item. It appears that I feel more vibration from the engine in the shifter than I did before at idle. Is the new flywheel lighter than the stock one and allowing more vibration to come through?
Old 04-13-2007, 12:40 PM
gus's 03's Avatar
its probably a normal fly wheel rather than a dual mass fly wheel..
it's more durable, but may transmit a bit more NVH to the cab/drivetrain
Old 04-13-2007, 05:54 PM
wap
wap's Avatar
I cant say for sure this is what you are feeling but I do agree with Gus, it is probabley the differance in DM and SM
Old 04-13-2007, 07:03 PM
67guzzler's Avatar
NVH reduction is one of the reasons DC went with the DMF.....
(Acrynm-City, Baby! )
Old 04-14-2007, 09:15 PM
Dang's Avatar
The additional vibration does not bother me, I just want to know if I need to start checking of for a bad injector.
Old 04-14-2007, 10:51 PM
triplenickel's Avatar
The OFE is a pretty sweet piece isn't it! I think it's a great comprimise for moderate power levels.
Old 04-16-2007, 04:38 PM
Dang's Avatar
It definately grabs and goes. I can't wait to set the Smarty on #9 and see what that feels like. I have only been up to #5 so far. I need to get a few more miles on it first.
gzhel
10-14-2007 09:53 PM
dodgezilla04
12-04-2006 12:25 PM
BlueDually
07-04-2006 05:40 PM
Buckshotmckee
04-16-2006 08:38 AM
dodgediesel4x4
05-14-2005 06:33 PM
Quick Reply: New OFE Installed
