New lift pump/filter, low psi.
Old 12-02-2008, 03:23 PM
2tone12valve's Avatar
Truck is 98.5 2wd dually auto. Just replaced in-tank lift pump with brand new unit from mopar. New filter. Also replaced plastic lines at the tank due to the feed line being kinked. Running between 8-10 psi at idle and 4-5 psi loaded. To me this seems low, any ideas?
Old 12-02-2008, 06:10 PM
WestTN's Avatar
Yes, replace as many of the banjo fittings as possible. They are a major restriction even on a 100% stock truck. The big line or relocate kit from Geno's Garage will make a big difference. Before the kit I had 6 to 8psi at idle, 13 psi after. Full throttle came in at 4 before and 12 after.
Old 12-03-2008, 10:47 PM
thumper549's Avatar
in tank pump on a 98.5 ?? 1st I have herd of this...
Old 12-03-2008, 11:18 PM
johnh's Avatar
they say pressure is not important w/ the in tank pumps.
the flow is adequate for a stock engine
Old 12-03-2008, 11:47 PM
thumper549's Avatar
I have had my tank out........pretty sure no pump was in there (98.5)
Old 12-04-2008, 07:40 PM
nitrousn's Avatar
Thats about right. Remember its all about volume not pressure. The in tank conversion will kits always have a lower psi but also have a more solid delivery. The in tank pump is a pusher where the engine mounted pump is a puller.
Old 12-05-2008, 01:07 PM
rattlerbob5.9's Avatar
The engine mounted pump is a pusher style also - just some dum _zz engineer put it in the wrong place
Old 12-05-2008, 02:30 PM
SIXSLUG's Avatar
If his truck has had the factory relocation warranty repair done previously, it has the in tank pump.
Mine was just done last August and holds a steady 10 psi. The Dodge tech says this is enough. After the warranty expires I'm going to upgrade to an aftermarket system.
Kurt
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
Quick Reply: New lift pump/filter, low psi.
