New Here with a question
My truck is too tall for my garage! (4x4 2500)Has anyone done an airbag kit that can adjust the ride height of the truck without sacrificing ride/towing/etc? thx
1 Post
No air bag kits here, but is the front of the cab to tall or is it wanting to hit just at the back by the 3rd brake light? If it is just at the back, there are a couple of 1" spacers under the leaf springs that you can take out to lower the rear to match the front. Instead of installing a leveling kit to raise the front to match the back, lots of folks just remove a spacer or two in the rear to lower the back to match the front. Easy to do.
Airbags are for supporting extra weight if your truck is sagging you increase air pressure to return to stock height for weight transfer and balance. Airbags to lower a 3/4 ton would take extensive fabrication rear end remove leafs from leafpack or scrap leafs and go with 5 link rear end front you could make a custom airbag seat and eliminate front coil but all in all your taking many thousands You might just want to build a bigger garage
Your air bag suspension kit is available, it will run you about $5,000.00. It is all bolt on stuff, give them a call.
www.kelderman.com
Mike
www.kelderman.com
Mike
Re: New Here with a question
bradmulvey
17
10-26-2005 11:08 AM
Dieseldude4x4
12-23-2002 08:56 PM
Dieseldude4x4
10-17-2002 04:58 PM
