New Here and ?? about boost gauge
Old 03-18-2004, 05:00 PM
turbododge2000's Avatar
i have a 2000 2500 and just got a boost gauge and were do i hook it up to thanks
Dan
Old 03-18-2004, 06:52 PM
SmokinDodge12V's Avatar
You can drill and tap the intake horn or there is a fitting you can get that uses a pre existing bolt hole in the intake.
Old 03-18-2004, 07:35 PM
billg's Avatar
You can look in my gallery I at the 4th picture. There is a plug on the intake manifold just to the right of the fuel filter. I think it is a ¾”. I think I used a ¾” to 1/8” brass pipe adapter.
Hope this helps.
Old 03-18-2004, 07:44 PM
Administrator / Scooter Bum
Shovelhead's Avatar
This is how I did the Drill & Tap fitting on mine.
1st I removed the intake horn to keep the shavings out of the engine.
Old 03-19-2004, 06:06 PM
Amish hauler's Avatar
I set mine up like billg. Why would you drill/tap the horn? Is there a more accurate reading here?
Old 03-19-2004, 06:48 PM
Shovelhead's Avatar
I'm kinduva Nutz & Boltz guy.
I figured it would be a cleaner install than the "side of the block with reducers" install, and those "special" bolts hadn't come out yet.
Old 03-19-2004, 07:14 PM
MCummings's Avatar
Another "side effect" of drilling and tapping in the intake horn is a "smoother" operating boost gauge, and it never emits a squeek (buzz, humm or any other noise.).
I put all my gauge installs there, unless specificly asked otherwise. Only downside is when doing a fuel filter, or LP replacement, the hose can get kinked, and a hole can be made if not carefull.
Merrick
Old 03-19-2004, 09:56 PM
thanks for your help i drill/tap the horn and i am runing about 18lb of boost is that good for a stock 2000 dodge 2500..
TIA
Dan
Old 03-19-2004, 10:49 PM
MCummings's Avatar
Yup. It's ok.
My '98.5 ran 16.5 or so. They should run between 18-20.
Make sure all your clamps are tight on your rubber boots, and that the rubber boot on the passenger side, closest to the intercooler isn't rubbing on the A/C line.
If it is, just bend the A/C line outta the way a little bit.
Merrick
Tank_66
02-28-2008 08:34 PM
turbomike
12-03-2007 09:31 PM
MoparMarv
05-04-2006 04:41 PM
Dieseldude4x4
12-23-2002 08:56 PM
Quick Reply: New Here and ?? about boost gauge
