New guy...need tow capacity ino
Hi everyone...we are thinking of buying 5th wheel...have an 06 ctd, 5.9, 3.73 gear ratio...automatic...3/4 ton mega cab.Does anyone have info on tow capacity...and since we will be towing a 5th wheel I guess also important is the payload since weight on rear axle.Also any tips /suggestions on type of hitch(slider type or not).
It would be good to hear from someone about how big/heavy 5th wheel you have and if happy with towing with similar vehicle to ours.
THANKS
THANKS
welcome to the site!! i cant help you with these questions but i'm sure that someone with the knowledge to help you will chime in. if you dont get the answers your looking for here try to post in the towing/hauling forum.
THANKS
THANKS
houg301:
Welcome to DTR!
To answer your question on the towing capacity of the 2006 Dodge CTD CR Pickups, here is an excerpt out of of the "Gulf Coast News":
__________________________________________________ __
"In addition to the most torque available in a production heavy-duty pickup, the Dodge Ram Heavy Duty boasts towing capability of 16,400 lbs., a payload of 5,020 lbs. and Gross Combined Weight Rating (GCWR) and Gross Vehicle Weight Rating (GVWR) of 23,000 lbs.and 12,200 lbs., respectively."
__________________________________________________ _____
So, it looks like the 2006 Dodge CTD CR Dually has a 16,400 lb. towing capability. As I recall, the single axle 2006's were around 15,000 lbs.
Hope that helps.
John_P
Here is a web site from Dodge that should help.
http://www-5.dodge.com/towing5/D/vehicle_to_weight.jsp
CrashCade
05-17-2005 12:09 PM
