New to first gen. have 4x4, BAD STEERING LINIKAGE
I am used to my 98 24v, auto. But just got a 93 stick shift 4x4 std. cab, ..to "work" with.
The steering wanders all over the place. I believe the box at the bottom (as well as tie rods...etc) is fine, but that linkage piece near the bottom of the steering column is shot all to hell.
One person told me "dodge" does not carry parts for thatanymore, and I'd have to do an aftermarket fix of some sort. So I thought someone on this site would have some knowledge on what to get and install/??
ANway, any help would be appreciated.
Also, is there a KDP with the 93 trucks....if so, I'll have to have that jigged or something asap.
Thanx,
Clay
Thanx,
Clay
That steering joint is a common point of failure. Get if fixed before it lets go!
You can get a kit at most parts stores to rebuild the stock joint or replace it with a much better unit from Borgenson.
http://www.borgeson.com/TruckProductDodge.htm
You can find them online for under 200 if you search around.
Dodge had the parts last summer. It's a waste of time to rebuild that joint on a 4X4 because it operates at a fairly extreme angle. Get the Borgeson or Flaming River shaft. On a 2wd the rebuild works great because the shaft is nearly straight.
1st Generation Admin
Be sure to check the steering box's mounting plate. They have an alarming failure rate with multiple cracks. DC's got them for around $25 I think it was.
Yup double ck that mounting plate, very common for cracks, mine had a hairline crack and the darn truck was all over the place...and all the bolts were tight. You can look in my gallery for my choice on the steering shaft, it`s the stock one with a spicer u-joint and yoke welded on, way over kill but it was 1/2 the price of a borg and it`s greaseable (borg is`nt). Don`t get me wrong the borg shaft is nice as well, i had one on another truck, very well made stuff, just throwing out another option for ya.
Puke,
There is less likely a problem with the dowel pin on a '93 compared to a 2nd gen. However, it can work loose and fall into the gears. More common on the 1st gen. are the timing case bolts that can work themselves loose and do the damage. When you get the cover off, see that these bolts get some loctite and retorque. Do a search in this forum for more info...
Thanx,
Clay
Thanx,
Clay
as for the steering "all over the place".An aftermarket shop has a "kit" they want to sell me for about $400.00cdn that i guess helps out alot for that problem.Mine isn't to bad yet.
Nice idea using that ujoint. You got any part numbers for that fix?
Thanks all of you. I got a steering column, made by borgeson.
I bought the deluxe one with a u joint on both ends (I was lucky because my rag joint was removeable...apparently a lot of them are not).
Took a couple hours to replace because they basically send it to you and you have to reduce the length a certain amount (they send them long because of all you guys that have their trucks lifted...etc., and need longer onesj_)..
But it's now perfect. Not a bit of play in the steering.
