New engine, tranny temp WAAAY up, or is it just the gauge?
Old 06-03-2010, 10:31 PM
snowmanx's Avatar
Just got my engine replaced last week and took it on its maiden voyage with 9000# 5th wheel. Very cool at 32*, snow, slush and rain, my diprocol tranny gauge starts reading very high....280*+ at one point. No apparent changes in the way the tranny felt, checked the fluid, it was good, and dipstick was only warm to touch.
I'm assuming it is the gauge, or the temp sensor? If it were really that hot wouldn't the dipstick be very hot as well? Tranny oil looked fine and didn't appear burnt.
Any comments would be appreciated.
Thanks.
Old 06-04-2010, 05:07 AM
1985cucv's Avatar
where is your temp probe located? feel the trans pan and if you cant keep your hand on it you may have issues! mine is warm but not extremely hot
Old 06-04-2010, 08:50 AM
klx650a2's Avatar
I had the exact same problem on my 2000 dodge (gauge, not engine). Check the ground on the tranny gauge. Mine was disconnected from when they replaced the heater core and it read VERY high, yet I could put my hand on the pan. Actually I would check all the wiring, just to be sure.
Old 06-04-2010, 08:56 AM
hoot's Avatar
I have a Diprocol trans temp gauge. I can assure you they are finnicky. Make sure you also have a clean connection at the sender. I used some dielectric grease on it. Also be careful to keep that wire away from noisy electric lines.
Old 06-04-2010, 08:01 PM
BLACKBEAR's Avatar
I don't thank pulling a fifth wheel with a new eng is a good way to brake one in!!!
Old 06-04-2010, 08:35 PM
SuperGewl's Avatar
That's the only real way to break in a NEW engine. Pull your trailer to the dealer, trade in the old truck, hook up the trailer to the NEW truck and head accross country. That's what a warranty is for.
Old 06-04-2010, 09:50 PM
p035970's Avatar
If you don't mind me asking, why did you have to replace the motor. My 2005 and I knew of 3 others here locally that dusted the motors. 2 lost the motors. All had stock filter setups. Dealer told me that Chrysler was aware of the filter boxes having sealing problems in some of the 2005's. Cleaned my intake, turbo, etc. and wanted to monitor. I didn't want the risk however and traded before a 100,000.
Old 06-05-2010, 02:18 PM
snowmanx's Avatar
Honestly, don't know for sure what took it out. Cummins mechanic seems to think poor fuel filtration, and a poor design that doesn't allow enough cooling at times and you melt here down.
Old 06-05-2010, 02:20 PM
snowmanx's Avatar
I've been told by many reliable sources that the best way to break them in is load them up and run them hard. Guess time will tell.
mar67655
03-21-2009 05:35 AM
DarrinGT
07-15-2008 01:33 PM
CORed
09-20-2007 12:03 PM
Racing_Joe66
06-12-2007 05:06 AM
firesine
11-24-2005 10:58 AM
Quick Reply: New engine, tranny temp WAAAY up, or is it just the gauge?
