New to diesels
Old 01-07-2012, 09:05 PM
daydreamer36535's Avatar
New to diesels
Hi all,
I understand you are supposed to idle the engine for a few minutes before shutting down....is that correct and why ?
thanks,
Joe
Old 01-07-2012, 09:34 PM
Administrator/Jarhead
madhat's Avatar
Hi, Joe, welcome to the DTR.
Yes, you should idle the motor depending on the load you had on it.
If you have an EGT gauge, you can wait until it is below 350* to shut down. If you don't, there is a guide in the owners manual that tells you how long to wait depending on what you were doing.
By letting the EGT's cool off, you reduce the chance the oil coking in the turbo and gumming the oil path up.
From Page 215, chapter 5 of the owners manual...
Idle the engine a few minutes before routine shutdown.
After full load operation, idle the engine 3 to 5 minutes
before shutting it down. This idle period will allow the
lubricating oil and coolant to carry excess heat away from
the combustion chamber, bearings, internal components,
and turbocharger. This is especially important for turbocharged,
charge air cooled engines, like your Turbo Ram.
It would also help to know what year truck and the mods you have... fill your sig out so we know.
How to:
https://www.dieseltruckresource.com/...e-t224825.html
HTH.
mad
Old 01-08-2012, 06:43 PM
Thanks guys...got the idea.
i edited my sig, but this truck is so new to me i'll have to re edit when i know more about it..
thanks again
Joe
warlock4x4
Introductions / New People
05-23-2008 05:25 PM
Bearwhiz
12-04-2006 07:41 AM
chips2002
11-23-2003 08:52 PM
TheMoose
08-06-2003 08:47 AM
blownbanana
11-16-2002 09:22 AM
Quick Reply: New to diesels
