new on diesel/shut off on a/c and turn
Old 11-01-2003, 05:37 PM
merenguecaliente's Avatar
??? I trying to get must help possible on this matter,
am new with this truck Dodge ram diesel cuming 5.9 3500 2wd 1996/110,000miles
I get couple weeks ago for almost 10g
since I had turn the a/c on ,for any reason,
the speed in the engine low in the tachom and if I try to turn the truck it shut off, I guess have to do with a vac,
can some tell me something, before I go to the dealer, I mean to have a good idea to tell,.
I check all possible reason that are on my hand but all seen to be ok, what I`m missing?
Old 11-01-2003, 06:49 PM
Mostwanted's Avatar
Re:new on diesel/shut off on a/c and turn
I am not sure if I am reading your post correctly. If you are asking why your truck dies when the A/C is on and you are turning, you probley just need to bump up th idle a little. If this is all happening at low speed wnile you are coasting, than the idle is the problem. It may also occur in reverse. In order to adjust the idle, you need to feel under the top of the pump behind the throttle linkages. You will find a screw under there.
dkimmel
01-03-2011 10:54 PM
randyswelding
02-09-2009 10:40 PM
stealman1
11-09-2007 11:07 AM
Dean Snow
09-26-2007 03:40 PM
Quick Reply: new on diesel/shut off on a/c and turn
